Triple Video Processor
Primary Functions
Wide bandwidth DC utility mixer, brightness (bias) and contrast (gain) processing, modulation summing
Triple Video Processor is a wide bandwith signal processor suitable for adjusting the gain and bias of three simultaneously processed signals, while also allowing secondary signals to be summed into the final output mix. Triple Video Processor was designed specifically to address common use case scenarios within the video synthesis system. Since the bias is applied to the input signal before it’s scaling & inversion control, the cross-over point at which the signal is inverted can be adjusted, enabling bi-polar voltage mixing when the signal is summed with the B input channel.
Specifications
Width
Mounting Depth
Power Consumption
Bandwidth
Price
10HP (2 inches)
1.25 inches
TBA
40MHz
$199
Frontpanel Key
Block Diagram
Where to purchase
Purchase this module at Analogue Haven.
If you have any additional questions about this module that you feel were not answered on this page, please e-mail us and let us know.
© 2010 LZX INDUSTRIES. ALL RIGHTS RESERVED.
